Need some help trying to apply an iRule
I am trying to apply one iRule on on of the VIP, but it gives me an error as below: 01070394:3: HTTP_REQUEST event in rule (Clickability_iRule) requires an associated HTTP or FASTHTTP profile on the virtual server (ws-uat-phx).
Now, I understand that this could probably be because of the "Performance(Layer 4)" Type but I see a document which tells me that iRules work on this type of VIP: http://support.f5.com/kb/en-us/solutions/public/12000/200/sol12272.html
Is this because of the HTTP_REQUEST mentioned in the iRule? Can I create the iRule in a different manner?
regards, Nikhil
- THi
Assume you have associated an HTTP or FastHTTP profile with the Virtual server? Default setting is none. If not, then you cannot use HTTP_REQUEST event and Layer 7 commands.
On Performance Layer 4 virtual server you might use CLIENT_ACCEPTED event, but depends on what the iRule does. With Performance Layer 4 you cannot use Layer 7 commands in the iRule. If you must, then you might use Performance HTTP virtual server.
- N_67263
Thanks Thi, this helps me understand what could be the issue.
