Need help with sFTP please.
Hi Guys,
I need assistant with setting up SFTP through F5 please.
My environment is as follows
Public IP Address > NAT'd to External DMZ IP - our External DMZ VLAN will need to exits the F5 on our Internal DMZ VLAN. How do I go about accomplishing this through F5 please?
Thank u
- Vijay_E
Cirrus
Are you load balancing SFTP connections or is it passing through the F5 to a server behind it ?
Have you tried setting it up and is it not working ? If so, what is your current setup ?
- berkleyapac_259
I deleted all profiles except for the VIP. Also, from the internal DMZ I can definitely ping the VIP. However, SFTP is still failing when coming from the cloud. I can definitely see the on the FW that SSH coming for that public ip is allowed.
- james_lee_31100
It doesn't support snat, try point your pool member gateway to lb floating ip
