Need help with rewrite but can't use profiles :(
Love the community here and i am looking for a little help. To start off i only have APM enabled so i can't use the LTM rewrite profiles. (really sucks). I need to create the following re-write:
https://field.test2.company2.com/bix-test/interface.aspx -> https://test.company.com/LegacyRequest/Interface.aspx
I have been toying with the following irule but i think i need a little help because i get page can't be displayed.
when RULE_INIT {
Log debug output to ltm logs - 1=yes, 0=no
set rwdebug 0
Set up variables for the irule and sets the default behavior of the STREAM profile. .
set chk_resp_rw 0
set clientHost "field.test2.company2.com"
set serverHost "test.company.com"
STREAM::disable
Below check if the http request is from the HOST and starting URI that requires the rewrite.
if {[string tolower [HTTP::host]] equals $clientHost && [string tolower [HTTP::uri]] starts_with "/bix-test/"}{
HTTP::header replace Host $serverHost
HTTP::uri /LegacyRequest/Interface.aspx
set chk_resp_rw 1
if {$wdebug}{ log local0. "Host Rewrite: [HTTP::host] , Context URI = [HTTP::uri]"}
when HTTP_RESPONSE {
Check server response for rewrites
if {$chk_resp_rw}{
STREAM expression changes all references in the response payload with the desired rewrite
if {[HTTP::header value Content-Type] contains "text"}{
STREAM::expression @$serverHost@$clientHost@
STREAM::enable
if {$wdebug}{ log local0. "response Rewrite done: "}
Check Location header for desired rewrite
if { [HTTP::header exists Location]}{
HTTP::header replace Location [string map -nocase {$serverHost $clientHost} [HTTP::header Location]]
I have stream turned on, on the virtual server. Any advice would be great guys, thanks!
- Walter_Kacynski
Let's start with any error message from /var/log/ltm when you run this request.
- cjunior
Nacreous
With a fast review, I see this possible mistake (variable name declaration): set rwdebug 0 But you are calling for if { $wdebug }{ log local0. "..... So, it should be: if { $rwdebug }{ log local0. ".....And maybe the:
should be just this:HTTP::header replace Host $serverHostHTTP::host $serverHostI have not tested, so, I hope it helps.
Here is some of the errors from the ltm file
Nov 3 07:16:34 DCAK12F5A err mcpd[8848]: 01070151:3: Rule [/Common/benson_rewrite_irule] error: /Common/benson_rewrite_irule:14: error: [undefined procedure: /LegacyRequest/Interface.aspx&8221][/LegacyRequest/Interface.aspx&8221;] Nov 3 07:17:44 DCAK12F5A err mcpd[8848]: 01070151:3: Rule [/Common/benson_rewrite_irule] error: /Common/benson_rewrite_irule:14: error: [unexpected extra argument "Uri"][HTTP::uri replace Uri &8220;] /Common/benson_rewrite_irule:14: error: [undefined procedure: /LegacyRequest/&8221][/LegacyRequest/&8221;]
