Need help with pool selection based on URI
This rule doesn't show any syntax errors in the editor, but I am not getting traffic to the pools. The rule resides in the Common partition and points to the pools using a path structure:
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { "/accountsearchdev.somewhere.com/" { pool "/test-partition/accountsearchdev.somewhere.com-1080" } "/maintenancedev.somewhere.com/" { pool "/test-partition/maintenancedev.somewhere.com-1081" } "/passportnetdev.somewhere.com/" { pool "/test-partition/passportnetdev.somewhere.com-1082" log "Matched to passportnetdev.somewhere.com-1082"} "/agentsearchdev.somewhere.com/" { pool "/test-partition/agentsearchdev.somewhere.com-1083" } "/contracdev.somewhere.com/" { pool "/test-partition/contracdev.somewhere.com-1084" } "/mftransferdev.somewhere.com/" { pool "/test-partition/mftransferdev.somewhere.com-1085" } "/mfreportsdev.somewhere.com/" { pool "/test-partition/mfreportsdev.somewhere.com-1086" } "/esignaturereportsdev.somewhere.com/" { pool "/test-partition/esignaturereportsdev.somewhere.com-1087" } "/helpdeskdev.somewhere.com/" { pool "/test-partition/helpdeskdev.somewhere.com-1088" } "/batchimportmgrdev.somewhere.com/" { pool "/test-partition/batchimportmgrdev.somewhere.com-1089" } "/iprmdev.somewhere.com/" { pool "/test-partition/iprmdev.somewhere.com-1090" } "/passportadmindev.somewhere.com/" { pool "/test-partition/passportadmindev.somewhere.com-1091" } "/prevailintegrationdev.somewhere.com/" { pool "/test-partition/prevailintegrationdev.somewhere.com-1092" } "/qivadmindev.somewhere.com/" { pool "/test-partition/qivadmindev.somewhere.com-1093" } "/qivconfigdev.somewhere.com/" { pool "/test-partition/qivconfigdev.somewhere.com-1094" } "/quotetracdev.somewhere.com/" { pool "/test-partition/quotetracdev.somewhere.com-1095" } "/stratreportdev.somewhere.com/" { pool "/test-partition/stratreportdev.somewhere.com-1096" } default { log "Request: [HTTP::uri] from [IP::client_addr] failed - no match in list" }}}
Hi!
You can try this rule to see what's coming in:
when HTTP_REQUEST { log local0. "Incoming URI: [string tolower [HTTP::uri]]" switch -glob [string tolower [HTTP::uri]] { "/accountsearchdev.somewhere.com/" { pool "/test-partition/accountsearchdev.somewhere.com-1080" } "/maintenancedev.somewhere.com/" { pool "/test-partition/maintenancedev.somewhere.com-1081" } "/passportnetdev.somewhere.com/" { pool "/test-partition/passportnetdev.somewhere.com-1082" log "Matched to passportnetdev.somewhere.com-1082" } "/agentsearchdev.somewhere.com/" { pool "/test-partition/agentsearchdev.somewhere.com-1083" } "/contracdev.somewhere.com/" { pool "/test-partition/contracdev.somewhere.com-1084" } "/mftransferdev.somewhere.com/" { pool "/test-partition/mftransferdev.somewhere.com-1085" } "/mfreportsdev.somewhere.com/" { pool "/test-partition/mfreportsdev.somewhere.com-1086" } "/esignaturereportsdev.somewhere.com/" { pool "/test-partition/esignaturereportsdev.somewhere.com-1087" } "/helpdeskdev.somewhere.com/" { pool "/test-partition/helpdeskdev.somewhere.com-1088" } "/batchimportmgrdev.somewhere.com/" { pool "/test-partition/batchimportmgrdev.somewhere.com-1089" } "/iprmdev.somewhere.com/" { pool "/test-partition/iprmdev.somewhere.com-1090" } "/passportadmindev.somewhere.com/" { pool "/test-partition/passportadmindev.somewhere.com-1091" } "/prevailintegrationdev.somewhere.com/" { pool "/test-partition/prevailintegrationdev.somewhere.com-1092" } "/qivadmindev.somewhere.com/" { pool "/test-partition/qivadmindev.somewhere.com-1093" } "/qivconfigdev.somewhere.com/" { pool "/test-partition/qivconfigdev.somewhere.com-1094" } "/quotetracdev.somewhere.com/" { pool "/test-partition/quotetracdev.somewhere.com-1095" } "/stratreportdev.somewhere.com/" { pool "/test-partition/stratreportdev.somewhere.com-1096" } default { log "Request: [HTTP::uri] from [IP::client_addr] failed - no match in list" } } }This rule only matches URI's that is an exact match.
Ie.
It will match but not
If you want to match you need to add a wildcard. Something like this:
when HTTP_REQUEST { log local0. "Incoming URI: [string tolower [HTTP::uri]]" switch [string tolower [HTTP::uri]] { "/accountsearchdev.somewhere.com/*" { pool "/test-partition/accountsearchdev.somewhere.com-1080" } "/maintenancedev.somewhere.com/*" { pool "/test-partition/maintenancedev.somewhere.com-1081" } "/passportnetdev.somewhere.com/*" { pool "/test-partition/passportnetdev.somewhere.com-1082" log "Matched to passportnetdev.somewhere.com-1082" } "/agentsearchdev.somewhere.com/*" { pool "/test-partition/agentsearchdev.somewhere.com-1083" } "/contracdev.somewhere.com/*" { pool "/test-partition/contracdev.somewhere.com-1084" } "/mftransferdev.somewhere.com/*" { pool "/test-partition/mftransferdev.somewhere.com-1085" } "/mfreportsdev.somewhere.com/*" { pool "/test-partition/mfreportsdev.somewhere.com-1086" } "/esignaturereportsdev.somewhere.com/*" { pool "/test-partition/esignaturereportsdev.somewhere.com-1087" } "/helpdeskdev.somewhere.com/*" { pool "/test-partition/helpdeskdev.somewhere.com-1088" } "/batchimportmgrdev.somewhere.com/*" { pool "/test-partition/batchimportmgrdev.somewhere.com-1089" } "/iprmdev.somewhere.com/*" { pool "/test-partition/iprmdev.somewhere.com-1090" } "/passportadmindev.somewhere.com/*" { pool "/test-partition/passportadmindev.somewhere.com-1091" } "/prevailintegrationdev.somewhere.com/*" { pool "/test-partition/prevailintegrationdev.somewhere.com-1092" } "/qivadmindev.somewhere.com/*" { pool "/test-partition/qivadmindev.somewhere.com-1093" } "/qivconfigdev.somewhere.com/*" { pool "/test-partition/qivconfigdev.somewhere.com-1094" } "/quotetracdev.somewhere.com/*" { pool "/test-partition/quotetracdev.somewhere.com-1095" } "/stratreportdev.somewhere.com/*" { pool "/test-partition/stratreportdev.somewhere.com-1096" } default { log "Request: [HTTP::uri] from [IP::client_addr] failed - no match in list" } } }Hope that helps.
/Patrik
- TLBrown_220661
That's very odd - when I pasted the rule in here it had *s in it - looking to match the phrase no matter what precedes or folows it - let me try again:
- Please use the preformatted code option in the forum. The rule is unreadable and I don't really feel like formatting it again for you. :)
- TLBrown_220661
I'd love to, if I can figure out how.
- TLBrown_220661
text - TLBrown_220661
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { "*/accountsearchdev.somewhere.com/*" { pool "/test-partition/accountsearchdev.somewhere.com-1080" } "*/maintenancedev.somewhere.com/*" { pool "/test-partition/maintenancedev.somewhere.com-1081" } "*/passportnetdev.somewhere.com/*" { pool "/test-partition/passportnetdev.somewhere.com-1082" log "Matched to passportnetdev.somewhere.com-1082"} "*/agentsearchdev.somewhere.com/*" { pool "/test-partition/agentsearchdev.somewhere.com-1083" } "*/contracdev.somewhere.com/*" { pool "/test-partition/contracdev.somewhere.com-1084" } "*/mftransferdev.somewhere.com/*" { pool "/test-partition/mftransferdev.somewhere.com-1085" } "*/mfreportsdev.somewhere.com/*" { pool "/test-partition/mfreportsdev.somewhere.com-1086" } "*/esignaturereportsdev.somewhere.com/*" { pool "/test-partition/esignaturereportsdev.somewhere.com-1087" } "*/helpdeskdev.somewhere.com/*" { pool "/test-partition/helpdeskdev.somewhere.com-1088" } "*/batchimportmgrdev.somewhere.com/*" { pool "/test-partition/batchimportmgrdev.somewhere.com-1089" } "/*iprmdev.somewhere.com/*" { pool "/test-partition/iprmdev.somewhere.com-1090" } "/*passportadmindev.somewhere.com/*" { pool "/test-partition/passportadmindev.somewhere.com-1091" } "/*prevailintegrationdev.somewhere.com/*" { pool "/test-partition/prevailintegrationdev.somewhere.com-1092" } "*/qivadmindev.somewhere.com/*" { pool "/test-partition/qivadmindev.somewhere.com-1093" } "*/qivconfigdev.somewhere.com/*" { pool "/test-partition/qivconfigdev.somewhere.com-1094" } "*/quotetracdev.somewhere.com/*" { pool "/test-partition/quotetracdev.somewhere.com-1095" } "*/stratreportdev.somewhere.com/*" { pool "/test-partition/stratreportdev.somewhere.com-1096" } default { log "Request: [HTTP::uri] from [IP::client_addr] failed - no match in list" }}} - TLBrown_220661
Thanks for pointing me to that, haven't posted here before.
- Perfectly fine. Almost everyone does it. :)
Please add this one as I suggested earlier to see what the incoming URI is:
log local0. "Incoming URI: [string tolower [HTTP::uri]]"That might help figuring out why it does not match any of the cases.
/Patrik
That's too bad. Since they wont let you change things I assume the request are actually landing somewhere? Can't you check the Web server logs?
/Patrik
- stan_piron
Cumulonimbus
does not contains hostname,[HTTP::uri]
is the right variable in the switch command.[HTTP::host]when HTTP_REQUEST { switch [string tolower [HTTP::host]] { "accountsearchdev.somewhere.com" { pool "/test-partition/accountsearchdev.somewhere.com-1080" } "maintenancedev.somewhere.com" { pool "/test-partition/maintenancedev.somewhere.com-1081" } "passportnetdev.somewhere.com" { pool "/test-partition/passportnetdev.somewhere.com-1082" log "Matched to passportnetdev.somewhere.com-1082"} default { log "Request: [HTTP::host] from [IP::client_addr] failed - no match in list" } } }
