Billy_14103
Jun 12, 2012Need help with Lync Edge Servers
Can anyone give me some guidance on setting up our lync edge servers behind our F5? I've got two edge servers set up per MS documentation. Each have 3 public IPs, one assign to each service. And also...
SteveMP
Jun 13, 2012Which version of the doc did you use. I remember one of the early ones I used it didnt work. I figured out by removing the SSl profiles it worked. The new version of the doc has fixed it. It looks like you have a SSL client profile so you may have just used an older version of doc. Set it to none and it should work. BTW, you are using Source Address Affinity for persistence method, correct?
