Billy_14103
Jun 12, 2012Need help with Lync Edge Servers
Can anyone give me some guidance on setting up our lync edge servers behind our F5? I've got two edge servers set up per MS documentation. Each have 3 public IPs, one assign to each service. And also...
mikeshimkus_111
Jun 12, 2012Historic F5 Account
Hi Billy, which documentation did you follow? Are you using the iApp template, or configuring manually? We highly recommend the template if you are running BIG-IP v11.0 or higher.
Generally, the VIPs for the Edge interfaces would live on the external BIG-IP, while the internal Edge VIPs live on the internal BIG-IP and receive outbound connections from clients and the Front End servers. Do you have two pair of BIG-IPs isolating your Edge servers in a DMZ, or are you doing this all on one BIG-IP (or pair)?
Feel free to upload the screenshots and we'll have a look.
thanks
Mike
