Need help with Cisco ACE header rewrite to irule
I need some help doing this conversion from Cisco Ace to iRule. There is a header request that convert the users URL request from "hostA.companyA.com/whatever/comes/after" replace "host1.companyA.com:64592/whatever/comes/after" and a header response that converts it back so the user will only see hostA.companyA.com/whatever/comes/after. We need to make the rewrite transparent to the user and the '/whatever/comes/after' will need to stay the same.
There is the ACE code..
action-list type modify http login header rewrite request Host header-value "hosta[.]companyA[.]com(.)" replace "host1.companyA.com:64592%1" header rewrite response Location header-value "https://host1.companyA.com:64592/(.)" replace "https://hosta.companyA.com/%1"
Hi John,
an ACE action-list of...
action-list type modify http login header rewrite request Host header-value "hosta[.]companyA[.]com(.)" replace "host1.companyA.com:64592%1" header rewrite response Location header-value "https://host1.companyA.com:64592/(.)" replace "https://hosta.companyA.com/%1"... could be translated to ...
when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "hosta.companya.com" } then { HTTP::header replace Host "host1.companyA.com:64592" } } when HTTP_RESPONSE { if { [string tolower [HTTP::header value Location]] starts_with "https://host1.companya.com:64592" } then { HTTP::header replace Location "https://hosta.companyA.com[getfield [HTTP::header value Location] ":64592" 2]" } }Note: I'm using
to make it more robust. So keep an eyee on lower CASE formating for the equals and starts_with comparsions.[string tolower]Cheers, Kai
- JohnL_247646
What is 2 after ":64592" 2]" ?
- Getfield splits the given input on every ":64592" and then uses the 2nd block...
- JohnL_247646
I modified that a bit in my testing enviroment when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "lb.abc.com" } then { HTTP::header replace Host "10.10.192.111" } } when HTTP_RESPONSE { if { [string tolower [HTTP::header value Location]] starts_with "http://" } then { HTTP::header replace Location "https://lb.abc.com[getfield [HTTP::header value Location] ":80" 2]" } } Not working and keep getting this in the ltm log. error: [undefined procedure: HTTP::Location][HTTP::Location]
