nanselmo_108951's avatar
nanselmo_108951
Dec 17, 2012
Need help with a SNAT iRule
So I have an iRule which will effectively SNAT everything to the VIP address, but I need to modify it to ONLY SNAT traffic where the source subnet is the same as the destination subnet. Any help here would be greatly appricated.
rule ir_snat2vip {
when CLIENT_ACCEPTED {
set VirtualIP [clientside {IP::local_addr}]
snat $VirtualIP
We have other iRules which do the selective SNAT but each one has to be created and the subnet must be noted on each one. I would rather have it where there is just one standard iRule across all my devices and anytime an application needs SNAT we just apply the iRule. Below is an example of a selective SNAT rule.
rule ir_snat_10_42_20 {
if { [IP::addr [IP::client_addr] equals 10.42.20.0/24] } {
snatpool abc_snatpool
Sooooo... any help would be greatly appreciated.
  • I don't see any easy way of doing this but if all the networks are /24's perhaps you could compare the first three octets of client address to the virtual address using [IP::addr [IP::local_addr]. Unfortunately I don't have the skills (yet) to knock something up but I'm sure someone could help out.
  • hoolio's avatar
    hoolio
    Here's a tidbit I got from dev:
    You only need to convert one side to be a network and then it will mask both with that same network mask to see if it’s on the same network. So, either of these should be sufficient:
    [IP::addr [IP::addr [IP::client_addr] mask 255.255.255.0] equals [LB::server addr]]
    or
    [IP::addr [IP::client_addr] equals [IP::addr [LB::server addr] mask 255.255.255.0]]
    It would be nice to add an option to IP::addr for a mask to apply. As in:
    [IP::addr –prefixlen 24 [IP::client_addr] equals [LB::server addr]]
    or
    [IP::addr –mask 255.255.255.0 [IP::client_addr] equals [LB::server addr]]
    There's a request for enhancement for an option like the last two:
    BZ376898: RFE improve IP::addr command to allow for simpler subnet comparison using prefixes
    Aaron
  • So a friend also suggested using a data group list on each LTM I use this on, just giving the DGL a standard name so the rule can be applied to each without needing to be edited.
    In that DGL, just define the networks for the pool members. The problem there is that we would have to maintain that DGL on each LTM when networks change. Sadly, that happens more often than I think I want to mess with around here.
