KT's avatar
KT
Dec 16, 2021
Need help to understand the iRule
switch -glob [string tolower [HTTP::uri]] {
                                              "/online*" { set is_redirected "legacy" }
switch $is_redirected {
              "legacy" {
                                            if { [LB::status pool one_digital_ratio_fr_http member 1.1.1.1 80] eq "up" } {
                                                           LB::detach
                                                           pool one_digital_ratio_fr_http member 10.101.83.80 80
                                                           #log local0.info "!!! FR DIGITAL REDIRECT - LEGACY"
                                                           #log local0.info "Persist server Legacy down! Redirecting"
                                                           LB::detach
                                                           pool two_digital_ratio_fr_http member 2.2.2.2 80
  • First it checks the URI. If it is starting with "/online*" the variable 'is_redirected' is set to "legacy".
    Next, it's checking if the "is_redirected" variable is set to "legacy". If it matches "legacy" it will check if pool member 1.1.1.1:80 is up. If it is up, it will make a new load balancing deciscion and set's the selected pool member to 10.101.83.80. If 1.1.1.1:80 is down, it will make a new load balancing deciscion and set's the selected pool member to 2.2.2.2:80.
