need help to simple redirect and whitelist of uri
hi out there I have a few small problems whereto I need a bit help - first I need to ensure that when a client visits a given site he will be directed to only one uri - eg:
external is we launching https://front-site.dk which internally connects to http://web01.internal.local/webconnect
second I need to ensure that only a given set of uri's can be accessed - eg:
https://front-site.dk/webservice1.aspx https://front-site.dk/webservice2.aspx but not f.ex webservice3.aspx
I have tried to look at a solution offered to one here which where running on a ltm 9.x - we have 11.3 - but I have some problems with getting the syntax correct for the datagroups - can you try to show me a simple sample? I have been looking at the fields offred in the http-profile for uri's - can this be used for this? And if so - how?
best regards /ti
