need help to modify header, stream irule
We have a problem right now, basically the client's application is load balanced through virtual server 10.4.2.106:443 and pool members 10.4.2.101:8888 and 10.4.2.102:8888
If you access https://10.4.2.106, it will show what is displayed on 10.4.2.101:8888 or 10.4.2.102:8888.
We access their application directly to the nodes through 10.4.2.101:8888/trips-gui/faces/login/Welcome.jspx and 10.4.2.102:8888/trips-gui/faces/login/Welcome.jspx. It will then redirect to:
or
For some reason, they cant change it. They want etis-app1-prod:8888 and etis-app2-prod:8888 to not show on the header. They want it replaced by https://etis.bir.gov.ph/ and without port.
So i made this iRule:
STREAM::disable
HTTP::header remove Accept-Encoding
when HTTP_RESPONSE {
set internal_host "etis-app1-prod:8888"
set external_host "etis.bir.gov:8888"
set internal_host2 "etis-app2-prod:8888"
set external_host2 "etis.bir.gov:8888"
if { [HTTP::header exists Location] }{
HTTP::header replace Location [string map "$internal_host $external_host" [HTTP::header Location]]
HTTP::header replace Location [string map "$internal_host2 $external_host2" [HTTP::header Location]]
if { [HTTP::header Content-Type] contains "text" } {
STREAM::expression "@$internal_host@$external_host@"
STREAM::enable
after modifying the hosts file of the client, above irule will work:
etis.bir.gov.ph = 10.4.2.106 etis.bir.gov = 10.4.2.101 etis.bir.gov = 10.4.2.102
https://etis.bir.gov.ph/trips-gui/faces/login/Welcome.jspx will redirect to http://etis.bir.gov:8888/jsso/SSOLogin?appurl=http://etis-app1-prod:8888/trips-gui/faces/login/Welcome.jspx&appid=TRIPS-WEBetis-app1-prod8888
Their demands our: retain https://etis.bir.gov.ph/ on all connections, hide port 8888
What are the necessary configurations to meet our client's demand? We need your help.
