simpsjy_181842
Sep 23, 2016Need help redirecting a mixed case URI
I am trying to redirect http://onestop.uc.edu/classes/ViewClassOfferings1.html to http://onestop.uc.edu/classes/ViewClassOfferings.html. But because of the mixed cased page name, Tolower and Toupper don't work. Any help would be appreciated.
Hi Simpsjy,
if you're required to evaluate incomming HTTP requests with a [string tolower] syntax, then you have to make sure that your rule set is also defined with tolower formated syntax...
when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "onestop.uc.edu" } then { if { [string tolower [HTTP::path]] equals "/classes/viewclassofferings1.html" } then { HTTP::redirect "http://onestop.uc.edu/classes/ViewClassOfferings.html" } } }Cheers, Kai
