Sumit_Tyagi_121
Apr 07, 2013Need help on URL Redirection through possible irule
Please help in configuring my below requiremnt on F5 BIG-IP LTM 1600 ver11.3, as I have tried with some irules but no success
pool1_pool
Internal IP:port = 192.168.1.2:80 redirection from external VIP/URI 172.21.111.3/https://myuri.com/test1/*
pool2_pool
Internal IP:port = 192.168.1.2:8086 redirection from external VIP/URI 172.21.111.3/https://myuri.com/test2/*
pool3_pool
internal IP:port = 192.168.1.2:9000 redirection from external VIP/URI 172.21.111.3/https://myuri.com/test3/*
My one physical server running three webservers URI with seperate port defind above as internal IP & port so need to redirect the client SSL request to these three web with mappinp to myuri/test1, myuri/test2 & myuri/test3
Thanks for providing possible configuration & your expert comments
Regards,
Sumit
- Sumit_Tyagi_121
need your expert comment on below irule, can help in my requirement?
log local0. "in HTTP_REQUEST"
if { [HTTP::uri] starts_with "/test2" } {
pool pool2_pool
elseif {[HTTP::host] starts_with "/test3"}{
pool pool3_pool}
else {
pool pool1_pool}
} - Jnon
You syntax looks right, are you seeing any errors in the LTM log? What do you have for pool members?
if pool1_pool is the same our could be set as your default pool on the vip, you could eliminate the else statement.
can you add a log statement after each pool selection so you can test your rule?
Are any of the cases working?
