Himadri_Subudhi
Oct 09, 2023Need help in send and receive string set up for F5 ECV monitor when response is in json format
Hi Team, I am trying to set up monitoring for F5 load balancer pool. I am using below send and receive string however it does not work. It always shows status as RED even if server is UP. Send stri...
CA_Valli
MVP
Oct 09, 2023I believe UP syntax should be enough to match this response.
Can you try to add \r\nConnection: Close\r\n\r\n at the end of your send string and try again?
