Shoaib_020's avatar
Shoaib_020
Feb 26, 2021
Need help in creating a monitor
Hello All,
I got a requirement to create a monitor to check the health of a host.
Type the REST API command GET https://IP_Address:443/xxx.yyy
the response would be -
HTTP/1.1 200 OK
Please let me know what would be the format of send and receive string.
  • have you already tried yourself? there is lots of information on this available if you search, i would advise you to look at that and then try or show what you think it should be
    start here and follow the links:
    https://devcentral.f5.com/s/question/0D51T00006kH8mK/send-and-receive-string-explanation-in-a-http-monitor
