Thanadon_Wattan's avatar
Thanadon_Wattan
Oct 30, 2006
need help: https 1 VS to multiple pools by client IP
I would like to send traffic to different pool for different client IP in https connection. but I have no idea that I can write i-rule like this :
when CLIENT_ACCEPTED {
if { ( [IP::client_addr] == 10.20.30.40 ) and
( [TCP::local_port] == 443 ) } {
use pool gateway_3260
use pool gateway_443
Is it possible to do same as http in https connection
or i need to write it different.
more information :-
virtual server port : 443
F5 should not break ssl connection between client & server
or ssl should not terminate at F5
Thank you in advance for any idea,comment and help.
or let me know if you need more information.
  • hoolio's avatar
    hoolio
    If you want to have BIG-IP load balance the traffic to a pool of servers, you should be able to set up a standard TCP VIP on port 0 (any) and use the rule you listed above to route traffic based on client IP address and the requested port.
    However, based on the pool names you have listed, it looks like you might be wanting to use a forwarding VIP going to a pair of forwarding devices.
    If the latter is correct, check this thread (Click here) for some options and limitations on setting up a rule with a wildcard VIP.
    Aaron
