Need an irule to block incoming connections if not matching a defined data group of addresses
Hi
I am trying to create an irule to block incoming smtp connections unless the originating ip is part of the block of ip addresss i have created in a data group. Where can i find this? Sorry - new at this.
- DEJ
Hello,
Edit - just realized I had [TCP::client_addr] instead of [IP:client_addr]
I'm relatively new as well, but you may want to try the below. If the traffic is going to port 25 and the client IP is not included in your allow list, it is set to drop the traffic. All others will go to the default pool, if one is set.when CLIENT_ACCEPTED { Check if destination port is SMTP and the client IP is not in the allow list if {[[TCP::local_port] equals 25] and [class match [IP::client_addr] ne DATAGROUPNAME]}{ Drop the traffic drop } }- DEJ
I don't know where you are applying this iRule which is why I went ahead and specified the destination port.
- DEJ_159363
Cirrus
Hello,
I'm relatively new as well, but you may want to try the below. If the traffic is going to port 25 and the client IP is not included in your allow list, it is set to drop the traffic. All others will go to the default pool, if one is set.when CLIENT_ACCEPTED { Check if destination port is SMTP and the client IP is not in the allow list if {[[TCP::local_port] equals 25] and [class match [IP::client_addr] ne DATAGROUPNAME]}{ Drop the traffic drop } }- DEJ_159363
Cirrus
- cammy_178041
Thanks, the rule is being applied to the smtp virtual server which is only port 25. I wrote it like so: when CLIENT_ACCEPTED {
if { [matchclass [IP::client_addr] equals trusted_networks] } {
pool smtp_pool
reject
Where trusted_networks is the data group and smtp_pool is the pool associated with the virtual server. I applied this irule to the VS.
- DEJ
Looks good. I do have a suggestion. I'm guessing you're on 10.x code , if you're using 9.x ignore the rest of this. Switch to using 'class match' instead of 'matchclass', from posts I've seen it can cause issues when you migrate to 11.x code. There are also tests posted online indicating class match has better performance. Links used for research below: https://devcentral.f5.com/articles/comparing-irule-control-statements https://devcentral.f5.com/wiki/irules.matchclass.ashx
- cammy_178041
Thanks Dareuja, i realized that and switched to class match. Appreciate your help!
