Nedd help with https redirect
Hello Guys,
I need help with iRule.. I have created specific ip for redirection for my web site from http to https (even if contain IP).
Here what I did
when HTTP_REQUEST { if { [HTTP::host] contains "xyz.com" or "10.x.x.x" or "1x.x.x.x" } { HTTP::redirect https://www.xyz.com } }
When user send request to http://xyz.com redirection works fine. But if user try https://xyz.com/test (or anything after /) it’s redirecting back to https://www,xyz.com home page.
Is there a way to define rule so redirect with requested url ?
Thanks, GSingh
- shaggy
when HTTP_REQUEST { if { [HTTP::host] contains "xyz.com" or "10.x.x.x" or "1x.x.x.x" } { HTTP::redirect https://www.xyz.com[HTTP::uri] } }
- Gurinder_Singh_
Thanks Shaggy..but it's still redirecting back to home page.
here is what is did
let me know if i am doing it right?
Thanks, GSingh
- shaggy
The redirect portion looks correct, but the if statement looks off: if { [HTTP::host] contains "xyz.com" or [HTTP::host] contains "10.x.x.x" or [HTTP::host] contains "1x.x.x.x" }
- Gurinder_Singh_
Fix the statement, But still no luck .. redirecting back home page (https://www.xyz.com)
when HTTP_REQUEST { if { [HTTP::host] contains "xyz.com" or [HTTP::host] contains "10.x.x.x" or [HTTP::host] contains "1x.x.x.x" } { HTTP::redirect https://www.xyz.com[HTTP::uri] } }
- shaggy
Is a subsequent redirect coming from the server? I use this syntax often in iRules and have no issues (see the _sys_https_redirect iRule for an example of an f5-supplied iRule using the syntax). Have you tried testing from curl or another client that will show you exactly what is coming back from the F5?
