Technological_S
Sep 25, 2007NATor SNAT Problem
Hi all,
I need generate a iRule for dinamic NAT or SNAT for outbound traffic from my Internal Vlan (where the server are conneccted) based to destination address,
When the server start to the connection to the backoffice the is not necesary NAT or SNAT the connection is with the orginal IP addres. And when the server start a a connection to the Internet change the IP to a public IP addres.
I create the following iRule:
when CLIENT_ACCEPTED {
log local0. "local--> [IP::local_addr] :remote->:[IP::remote_addr]"
if { [matchclass [IP::remote_addr] equals $::tc_pat_hosts] }
log local0. "opcion1"
if { [matchclass [IP::local_addr] equals $::tc_pat_backoffice] }
forward
elseif { [ [IP::local_addr] equals 212.89.6.193] }
snat 192.168.106.254
else
snatpool PAT_SNAT_INTERNET
elseif { [matchclass [IP::remote_addr] equals $::tc_mmsc_hosts] }
log local0. "opcion2"
if { [matchclass [IP::local_addr] equals $::tc_mmsc_backoffice] }
forward
else
snatpool MMSC_SNAT_INTERNET
elseif { [matchclass [IP::remote_addr] equals $::tc_web_hosts] }
log local0. "opcion3"
if { [matchclass [IP::local_addr] equals $::tc_web_backoffice] }
forward
else
elseif { [matchclass [IP::remote_addr] equals $::tc_pre_web_hosts] }
log local0. "opcion4"
forward
log local0. "forward"
else
log local0. "else opcion 4"
else
forward
log local0. "local--> [IP::local_addr] :remoto-->:[IP::remote_addr]"
But I detect that when I apply the SNAT in the iRule is not a correct position, the SNAT apply to IP::local_addr and I would Like SNAT or NAT to the IP::client_addr.
Is necesary change the event ? or is necesary use another function like snat ?
- Colin_Walker_12Historic F5 AccountI'm not sure I understand your question. What do you mean it's applying to IP::local_addr? You're specifying a SNAT address, so I'm a little confused as to what you mean. Could you try to clarify a bit what you're trying to achieve versus what this rule is accomplishing?
Thanks,
Colin
