Angel_Martinez_'s avatar
Angel_Martinez_
Oct 05, 2009
MySQL Monitor EAV
Some previous releases BigIP LTM is using for internal features MySQL so we have available some MySQL tools like mysqlcheck ;o)
Using the EAV sample at /usr/bin/monitor/sample I have made this EAV monitor for checking my MySQL pools
[root@BIGIP:Active] log b monitor MySQL list
monitor MySQL {
defaults from external
args "USER PASSWORD DB"
run "mysql_check"
where mysql_check is:
[root@BIGIP:Active] log cat /usr/bin/monitors/mysql_check
!/bin/sh
these arguments supplied automatically for all external pingers:
$1 = IP (nnn.nnn.nnn.nnn notation or hostname)
$2 = port (decimal, host byte order)
$3 = Database Name
pidfile="/var/run/mysqlcheck.$1..$2.pid"
if [ -f $pidfile ]
then
kill -9 `cat $pidfile` > /dev/null 2>&1
fi
echo "$$" > $pidfile
node_ip=`echo $1 | sed 's/::ffff://'`
/usr/bin/mysqlcheck -h $node_ip -P $2 -u $3 --password=$4 -s -c $5
status=$?
if [ $status -eq " " ]
then
echo "up"
fi
rm -f $pidfile
echo "My log: IP-V6:$1 IP:$node_ip Port:$2 User: $3 Pass:$4 DB:$5" > /var/log/EXTERNAL.log
Have fun! ;o)
