Mutual SSL implementation using Layer 4 forwarding
Would it be possible to configure two-way SSL using layer 4 forwarding(Passthrough LB configuration)?
Our application is trying to authenticate client certificates but the connection fails with the below error -
SSL session initialization error, SSL_connect/accept failed, SSL_ERROR_SSL: error:140890C7:SSL routines:SSL3_GET_CLIENT_CERTIFICATE:peer did not return a certificate s3_srvr.c:3274 PeerIP=10.10.10.15
Where 10.10.10.15 is the SNAT IP of the virtual server. As per the above log, server is trying to obtain certificate from the LTM and is failing.
Is it possible to setup 2-way ssl using Layer 4 forwarding or do I need to setup 2 way SSL at the LTM by using a standard type virtual server and terminating the ssl?
- Kevin_Stewart
Employee
In the absence of client and/or server SSL profiles applied to the VIP, SSL traffic should pass directly through to the server. You should be able to create a standard type VIP and not apply SSL profiles, or possibly any other type of forwarding VIP.
