mpenglish_63863
Jun 18, 2014Multiple ports going to the same pool
We have a problem where we would like to do the following:
- Request coming is as https://app1.domain.com
- Irule picks this up and matches app1 via an external datagroup.
- If it matches app1 then we want to send the traffic to a pool on 4001.
We intend to have app2 – 4002, app3 – 4002 etc.
How/can we get this to work with one pool or do we have to have multiple pools with specific port numbers?
I have got the datagroup matching part sorted it’s the last bit to send traffic to a one on a specific port number.
Let me know if you need me info.
Mark
- PeteWhite
Employee
Pretty sure that you can only do this on the specific pool member rather that per pool. As you say, the best way would be to use multiple pools. Or use recursive VSs.
