Aaron_McMahon_2's avatar
Aaron_McMahon_2
Aug 27, 2007
Multi-CPU Usage
In a multi-CPU BIG-IP, what's the best way to get each CPU's usage as a percentage?
I've muddled through the iControl SDK for a while. I've pulled some test values out through iControl but I'm not sure I'm seeing what I'm looking for. I need to get each CPU's usage, and I need to convert the usage values to a percentage so that I can graph it. Basically, I need to create a CPU usage graph like the Windows Task Manager, updated every few seconds.
I'd appreciate a pointer or an explanation.
Thanks.
  • Okay, here's some code that sorta works. But the percentages I'm getting back are around 2.5% during each 5-second polling interval. The BIG-IP GUI shows usage around 7% to 10%.
    ' CPU METRICS
    cpu = BigIPInfo.get_cpu_usage_information()
    For t = 0 To cpu.usages.Length - 1
    RS.Open("SELECT * FROM CPU ORDER BY Timestamp DESC", Conn, ADODB.CursorTypeEnum.adOpenDynamic, ADODB.LockTypeEnum.adLockOptimistic)
    If RS.EOF Then
        WriteValues = False
        OldTotalCycles = 0
        OldIdleCycles = 0
    Else
        WriteValues = True
        OldTotalCycles = RS("TotalCycles").Value
        OldIdleCycles = RS("IdleCycles").Value
    End If
    RS.AddNew()
    RS("CPUNum").Value = cpu.usages(t).cpu_id
    ' System Cycles
    High = cpu.usages(t).system.high
    Low = cpu.usages(t).system.low
    TotalCycles = Convert_32_to_64(Low, High)
    ' User Cycles
    High = cpu.usages(t).user.high
    Low = cpu.usages(t).user.low
    TotalCycles += Convert_32_to_64(Low, High)
    ' Soft IRQ Cycles
    High = cpu.usages(t).softirq.high
    Low = cpu.usages(t).softirq.low
    ' IRQ Cycles
    High = cpu.usages(t).irq.high
    Low = cpu.usages(t).irq.low
    ' niced Cycles
    High = cpu.usages(t).niced.high
    Low = cpu.usages(t).niced.low
    ' IO/WAIT Cycles
    High = cpu.usages(t).iowait.high
    Low = cpu.usages(t).iowait.low
    Value += Convert_32_to_64(Low, High)
    ' Idle Cycles
    High = cpu.usages(t).idle.high
    Low = cpu.usages(t).idle.low
    IdleCycles = Convert_32_to_64(Low, High)
    ' Calculate Percentage as Total Cycles (new since last update) divided by Idle Cycles (also since last update)
    Percentage = (CType(OldTotalCycles, ULong) - TotalCycles) / (CType(OldIdleCyclesm, ULong) - IdleCycles)
    If Not WriteValues Then Percentage = 0
    RS("Usage").Value = Percentage
    RS("TotalCycles").Value = TotalCycles
    RS("IdleCycles").Value = IdleCycles
    Dim ThisDate As New Date(cpu.time_stamp.year, cpu.time_stamp.month, cpu.time_stamp.day, cpu.time_stamp.hour, cpu.time_stamp.minute, cpu.time_stamp.second)
    RS("Timestamp").Value = ThisDate
    RS.Update()
    RS.Close()
    Next
    Here are a few consecutive database records produced by this code:
    CPUNumTotalCyclesIdleCyclesUsageTimestamp
    070536758382930.026009988/27/2007 11:39:59 AM
    070535762382930.026036098/27/2007 11:39:53 AM
    0705347653829308/27/2007 11:39:48 AM
    070534765382930.025905528/27/2007 11:39:43 AM
    0705337733829208/27/2007 11:39:38 AM
    070533773382920.025958428/27/2007 11:39:32 AM
    0705327793829108/27/2007 11:39:27 AM
    070532779382910.026011338/27/2007 11:39:22 AM
    0705317833829008/27/2007 11:39:17 AM
  • Percentage = (CType(OldTotalCycles, ULong) - TotalCycles) / (CType(OldIdleCyclesm, ULong) - IdleCycles)
    I think that should be Percentage = 1-IdleCycles/TotalCycles; ok
