Cynthia_18735's avatar
Cynthia_18735
May 06, 2008
More efficient way to get pool member status per URL using iControl?
I have a perl script that is does the following:
(1) Gets a list of WideIP's from GlobalLB/WideIP
(2) For each WideIP, gets a list of Pool names from GlobalLB/Pool.
Input is an array of WideIP's (from 1)
(3) For each pool name in each WideIP, gets a list of pool members from GlobalLB/PoolMember:
Input is an array with a single pool name.
Output is address and port.
(4) For each address:port in each pool gets enabled/disabled state from GlobalLB/VirtualServer
Inut an Array with a single address and port
for each pool member
Output is enabled/disabled state.
So, this processes as follows:
- Retrieve WideiP list
Start Loop 1:
For each WideIP --> get poolnames
Start Loop 2:
For each Poolname
--> get poolmembers
Start Loop 3:
For each poolmember
--> get VirtualServer states
End Loop 3
End Loop 2
End Loop 1
This results in many HTTP/Soap requests hitting the GTM very quickly. Is there a better way to do this?
  • That's what the eval section of the code is supposed to do. It inserts the authentication headers in the first request (if you have a new enough version of SOAP::Lite. The issue with your code is that you are adding the headers to the $Rule object and not the $WIDEIP object that you are using.
    Give this a try:
     $WIDEIP = SOAP::Lite
     -> uri('urn:iControl:GlobalLB/WideIP')
     -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
     eval { $WIDEIP->transport->http_request->header
     'Authorization' =>
     'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
    -Joe
