jba3126's avatar
jba3126
Jul 09, 2019
Monitoring through a Secure Web Gateway using NTLM and Trusted CA
https://devcentral.f5.com/s/feed/0D51T00006i7XIKSA2https://devcentral.f5.com/s/feed/0D51T00006i7XIKSA2I'm working to load balance two Bluecoat SWG Proxies. At the moment I'm good with the load method albeit I'm curious if anyone has had any luck with SNAT and enabling X-Forward-For or equivalent. I'd like to mesh the two which creates return routing complications without the use of SNAT. When I run the following cURL command it works like a charm. Challenge is when I setup the equivalent HTTPS monitor I don't see it trying to connect to the proxy first, but rather I see the traditional SSL Client Hello and the Proxy sends a FIN which makes sense because it didn't attempt a CONNECT method and authorize the connection before setting up SSL.
cURL Command:
curl -v -I -x https://username:[email protected]:4438 --proxy-ntlm https://www.google.com --cacert CA-Int-Trusted.pem
I need to be able to translate this into an HTTPS monitor without having to resort to an external monitoring script that has a username and password are in clear text found in some of the posts on the same topic (See below).
/jeff
