Janduci_174111
Jan 12, 2017Monitoring the amount of connections for each node
Hello,
How Can I monitor the amount of connections for each node within a pool? I'm looking for OID/name in the file F5-BIGIP-LOCAL-MIB.txt, but I can't finding it!
Is there especific OID for this?
- Hamish
Cirrocumulus
Yes, you can...
In SNMP it's in the LtmPoolMemberStatEntry structure. You have the right file, it's in the F5-BIGIP-LOCAL MIB file. Line 2710 on the file I just grabbed from v12.1
LtmPoolMemberStatEntry ::= SEQUENCE { ltmPoolMemberStatPoolName LongDisplayString, ltmPoolMemberStatAddrType InetAddressType, ltmPoolMemberStatAddr InetAddress, ltmPoolMemberStatPort InetPortNumber, ltmPoolMemberStatServerPktsIn Counter64, ltmPoolMemberStatServerBytesIn Counter64, ltmPoolMemberStatServerPktsOut Counter64, ltmPoolMemberStatServerBytesOut Counter64, ltmPoolMemberStatServerMaxConns Counter64, ltmPoolMemberStatServerTotConns Counter64, ltmPoolMemberStatServerCurConns CounterBasedGauge64, ltmPoolMemberStatPvaPktsIn Counter64, ltmPoolMemberStatPvaBytesIn Counter64, ltmPoolMemberStatPvaPktsOut Counter64, ltmPoolMemberStatPvaBytesOut Counter64, ltmPoolMemberStatPvaMaxConns Counter64, ltmPoolMemberStatPvaTotConns Counter64, ltmPoolMemberStatPvaCurConns CounterBasedGauge64, ltmPoolMemberStatTotRequests Counter64, ltmPoolMemberStatTotPvaAssistConn Counter64, ltmPoolMemberStatCurrPvaAssistConn CounterBasedGauge64, ltmPoolMemberStatConnqDepth Integer32, ltmPoolMemberStatConnqAgeHead Integer32, ltmPoolMemberStatConnqAgeMax Integer32, ltmPoolMemberStatConnqAgeEma Integer32, ltmPoolMemberStatConnqAgeEdm Integer32, ltmPoolMemberStatConnqServiced Counter64, ltmPoolMemberStatNodeName LongDisplayString, ltmPoolMemberStatCurSessions CounterBasedGauge64, ltmPoolMemberStatCurrentConnsPerSec CounterBasedGauge64, ltmPoolMemberStatDurationRateExceeded CounterBasedGauge64 }
