david_MARTINEAU's avatar
david_MARTINEAU
Nov 30, 2009
Monitoring SQL Port
I'm a newbee in F5 BIG IP.
I would configure a monitor that only check the tcp port 3306 responding (like telnet server 3306)
the predefined monitor oracle or MSSQL are so advanced (sql request, database,...)
What monitor can i use ? with parameters ?
Best regards
David
FR
  • It's OK
    When the port are configured in the pool members, i just add tcp monitor and it's OK
    It's like telnet server port
    Regards
    David
    FR
  • hoolio's avatar
    hoolio
    Hi David,
    I assume you're using MySQL if you're trying to monitor port 3306. LTM currently provides built in monitors for Oracle, MS SQL databases--but not MySQL.
    The TCP monitor will check whether there is anything answering a three way handshake on the port. You could also use the mysql client on LTM to check that the server is running. Another user gave their solution for this in a post here:
    MySQL Monitor EAV
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=31&tpage=1&view=topic&postid=62989
    Aaron
