engterence5_272's avatar
engterence5_272
Sep 22, 2010
Monitoring Rate Shaping
Hi all, I've received a challenge to monitor a rate shaping applied onto 2 Virtual Servers with a bunch of pool members. The base rate is set as 2mbps, ceiling rate 3mbps and burst size 1mbps. Is there a way to monitor the traffic for the 2 Virtual Servers in real time (e.g plotting a graph) and able to show that the rate class is working effectively?
  • You can see bits in/out for a particular VS...you could clear the stats before your test and refresh every x seconds...or just poll that value via SNMP.
