hc_andy_35682
Feb 16, 2010Monitoring current traffic per VIP
Hi All,
Is there a way to monitor the traffic/bandwidth utilization per VIP.
I'm using BIG -IP LTM 6900 version 10.0.1. From the GUI, I can access virtual server statistics but they don't show the current bits and packets but only give you a total count. They do however show you the current connection count but I'm more interested in knowing the bandwidth utilization of the VIP.
Screen shot attached.
Thanks.
Andy
Sort By
- hc_andy_35682
I think it's a global setting only but not 100% sure. - hc_andy_35682
Sorry I know this is a dumb question, but does the little "m" in the graph indicate milli?? - JRahm
Admin
That's correct. - hc_andy_35682
Hi Jason, - JRahm
Admin
I'm always looking for suggestions to expand the template. The nodes are probably pretty easy, pool members will be more challenging. - Hamish
Cirrocumulus
I have some perl code that does this... Pulling the data is easy... (Although my code uses iControl, not SNMP). - JRahm
Admin
That would be incredibly useful. Does cacti have an API for actions like this? I haven't looked that deeply. Without, would be some serious DB work to make it happen. - Hamish
Cirrocumulus
I'd have to look. I suspect it doesn't and would require direct manipulation of the cacti database... - hc_andy_35682
I'm getting strange results for the number of current connections to our dns virtuals. We have two dns virtuals and the first one shows no current connections where as the second virtual always display this weird graph shape for the same time period. - Hamish
Cirrocumulus
Is your cacti server overloaded? The polling on cacti isn't very intelligent, and breaks easily under load. If your poll times go much above 30 seconds then you're heading into territory that will result in dropouts (Manifested usually as missing data).
