Monitor two pool maintenance page iRule using XFF not working...
- Jan 28, 2022
before working on this, it's very similar to your other one and I was curious if this is on the same virtual? If so, is the other logic in this rule as well or a different rule?
- Jan 28, 2022
I am not sure if the new site is formatting your iRule incorrectly or what but, it does not appear that the iRule will function as you want in the state I see it right now.
There are several things wrong with the logic so I am re-posting it here with clearing formatting and commented with the logic as it is:
when HTTP_REQUEST { set CHECK_IP [lindex [lsearch -all -inline -not -exact [split [HTTP::header values X-Forwarded-For] "\{\} ,"] {}] 0] # Check if userds are NOT in internal user DG if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { # Check if uri is in allowed list if { [class match -- [HTTP::uri] eq DG-ALLOWED-URI-LIST] } { #blocks external users (i.e. IPs Not in Interal Users DG) reject log local0. "Client IP Discard: \ [HTTP::host][HTTP::uri]->[IP::client_addr]" } # Check if External Pool has zero active members if { [active_members EXTERNAL-POOL] < 1 } { #IF so, check if they are "external" users (i.e. NOt in Internal users DG if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { #redirect external users to maintenance-page HTTP::redirect "http://maintenance-page.com/external" # returns form proccessing this event #### No other code in this iRuel will run!!!!!!! return ###### Rest of this logic will never be processed!!!! #################### # Check if internal Pool is down if { [active_members INTERNAL-POOL] < 1 } { # Check if IP IS in the Internal Uers group if { ([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { # redirect internal users to the maiantinace page if the internal pool is down HTTP::redirect "http://maintenance-page.com/internal" # returns form proccessing this event #### No other code in this iRuel will run!!!!!!! But we would never get this far anyway. return ###### Rest of this logic will never be processed!!!! #################### # Send traffic to external pool pool EXTERNAL-POOL # IF you are NOT in Internal Users DG } else { # Send to Internal Pool pool INTERNAL-POOL log local0. "the X-Forwarded-For header value is $CHECK_IP" } } } } } }
It is diffiucult to tell from the current logic exactly what you were trying to accomplish But this is my best guess at what it SHOULD look like:when HTTP_REQUEST { set CHECK_IP [lindex [lsearch -all -inline -not -exact [split [HTTP::header values X-Forwarded-For] "\{\} ,"] {}] 0] # Block external IPs form getting to ALLOWED-URI-LiST if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { if { [class match -- [HTTP::uri] eq DG-ALLOWED-URI-LIST] } { reject log local0. "Client IP Discard: \ [HTTP::host][HTTP::uri]->[IP::client_addr]" } } # If External Pool is down, redirect enternal users, and send internal users to Internal Pool if { [active_members EXTERNAL-POOL] < 1 } { if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { HTTP::redirect "http://maintenance-page.com/external" return } else { pool INTERNAL-POOL log local0. "the X-Forwarded-For header value is $CHECK_IP" } } # Check if Internal Pool is down, redirect External users to maintiencace page, and allow everyone else to External Pool if { [active_members INTERNAL-POOL] < 1 } { if { (![class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { HTTP::redirect "http://maintenance-page.com/internal" return } else { pool EXTERNAL-POOL log local0. "the X-Forwarded-For header value is $CHECK_IP" } } }
reject
return
return
pool EXTERNAL-POOL
pool INTERNAL-POOL
reject
return
pool INTERNAL-POOL
return
pool EXTERNAL-POOL
- ant77Jan 31, 2022
Joe/Jason -
thanks for your guidence. I have modified the irule a bit and got it working.
Thanks again guys!
