Monitor two pool maintenance page iRule using XFF not working...
- Jan 28, 2022
before working on this, it's very similar to your other one and I was curious if this is on the same virtual? If so, is the other logic in this rule as well or a different rule?
- Jan 28, 2022
I am not sure if the new site is formatting your iRule incorrectly or what but, it does not appear that the iRule will function as you want in the state I see it right now.
There are several things wrong with the logic so I am re-posting it here with clearing formatting and commented with the logic as it is:
when HTTP_REQUEST { set CHECK_IP [lindex [lsearch -all -inline -not -exact [split [HTTP::header values X-Forwarded-For] "\{\} ,"] {}] 0] # Check if userds are NOT in internal user DG if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { # Check if uri is in allowed list if { [class match -- [HTTP::uri] eq DG-ALLOWED-URI-LIST] } { #blocks external users (i.e. IPs Not in Interal Users DG) reject log local0. "Client IP Discard: \ [HTTP::host][HTTP::uri]->[IP::client_addr]" } # Check if External Pool has zero active members if { [active_members EXTERNAL-POOL] < 1 } { #IF so, check if they are "external" users (i.e. NOt in Internal users DG if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { #redirect external users to maintenance-page HTTP::redirect "http://maintenance-page.com/external" # returns form proccessing this event #### No other code in this iRuel will run!!!!!!! return ###### Rest of this logic will never be processed!!!! #################### # Check if internal Pool is down if { [active_members INTERNAL-POOL] < 1 } { # Check if IP IS in the Internal Uers group if { ([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { # redirect internal users to the maiantinace page if the internal pool is down HTTP::redirect "http://maintenance-page.com/internal" # returns form proccessing this event #### No other code in this iRuel will run!!!!!!! But we would never get this far anyway. return ###### Rest of this logic will never be processed!!!! #################### # Send traffic to external pool pool EXTERNAL-POOL # IF you are NOT in Internal Users DG } else { # Send to Internal Pool pool INTERNAL-POOL log local0. "the X-Forwarded-For header value is $CHECK_IP" } } } } } }
It is diffiucult to tell from the current logic exactly what you were trying to accomplish But this is my best guess at what it SHOULD look like:when HTTP_REQUEST { set CHECK_IP [lindex [lsearch -all -inline -not -exact [split [HTTP::header values X-Forwarded-For] "\{\} ,"] {}] 0] # Block external IPs form getting to ALLOWED-URI-LiST if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { if { [class match -- [HTTP::uri] eq DG-ALLOWED-URI-LIST] } { reject log local0. "Client IP Discard: \ [HTTP::host][HTTP::uri]->[IP::client_addr]" } } # If External Pool is down, redirect enternal users, and send internal users to Internal Pool if { [active_members EXTERNAL-POOL] < 1 } { if { !([class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { HTTP::redirect "http://maintenance-page.com/external" return } else { pool INTERNAL-POOL log local0. "the X-Forwarded-For header value is $CHECK_IP" } } # Check if Internal Pool is down, redirect External users to maintiencace page, and allow everyone else to External Pool if { [active_members INTERNAL-POOL] < 1 } { if { (![class match -- $CHECK_IP eq DG-INTERNAL-USERS-XFF]) } { HTTP::redirect "http://maintenance-page.com/internal" return } else { pool EXTERNAL-POOL log local0. "the X-Forwarded-For header value is $CHECK_IP" } } }
Hi Jason,
Yes, this is similar to the previous iRule, but for a different Virtual. We need to do this for the other one also...It seems that you can't have two monitor in one iRule, one monitoring an external pool, and the other monitoring the internal Pool...We need to use XFF to distinguish what traffic is what....I have tried re-ording the monitors, and when you disable the members for the "internal" pool, traffic still gets sent there...Is this a bug or something? This has nothing to do with the irule, but more of a pool configuration/disabling member...why does the website still comes up...and when you add the secondary monitor in the script in, external users will be routed to the internal pool instead of the external pool....Right now, i only have the script to include the external monitor...we can't have two for some reason..not sure if this is a bug or not...
Thanks!
