Monitor that uses openssl for OCSP
I'm looking to create a probe that can ascertain if our OSCP nodes are processing requests properly, instead of a standard TCP probe. I was hoping to use something similar to this "openssl ocsp -url -issuer /path/to/loaded/certs/cacert.pem -no_cert_verify -resp_text -serial 1" and validate off an expected response. I've done some looking around the forums but haven't come across anyone attempting something like this, or if there are any suggestions on a better way.
- Kevin_Stewart
Employee
You may have to tweak this a bit to get exactly what you want, but based on the sample (Bash) monitor:
!/bin/sh these arguments supplied automatically for all external pingers: $1 = IP (::ffff:nnn.nnn.nnn.nnn notation or hostname) $2 = port (decimal, host byte order) $3 and higher = additional arguments $MONITOR_NAME = name of the monitor In this sample script, $3 is the regular expression Name of the pidfile pidfile="/var/run/$MONITOR_NAME.$1..$2.pid" Send signal to the process group to kill our former self and any children as external monitors are run with SIGHUP blocked if [ -f $pidfile ] then kill -9 -`cat $pidfile` > /dev/null 2>&1 fi echo "$$" > $pidfile Remove the IPv6/IPv4 compatibility prefix node_ip=`echo $1 | sed 's/::ffff://'` Using the nc utility to get data from the server. Search the data received for the expected expression. openssl ocsp -CAfile subca1.f5labs.com.cer -issuer subca1.f5labs.com.cer -serial 4 -noverify -url http://$node_ip:$2 |grep "4: good" > /dev/null status=$? if [ $status -eq 0 ] then Remove the pidfile before the script echoes anything to stdout and is killed by bigd rm -f $pidfile echo "up" fi Remove the pidfile before the script ends rm -f $pidfileThen just apply this is as a standard external monitor.
- Johnny_Test_197
Thanks for both answers, I had essentially each component you have in the above script except I used a few more variables for the openssl command like this:
openssl ocsp -url http://$IP:$PORT -issuer $CERTFILE -no_cert_verify -resp_text -serial $SERIAL | grep $QUERYSTRING | cut -d " " -f2 > /dev/null
where $QUERYSTRING was "$SERIAL: " since I only want to test if the OSCP responder is processing requests, I don't really care if the response is "good" or "unknown" as long as it's a non error response. Both responses were helpful but I gave credit to Kevin since he spent more time on a full explanation.
