Mayank_Shukla
Altostratus
Jul 06, 2016Monitor Query
Hi
I configured an https monitor in LTM .Then created a node and called the same in a pool. This monitor was available in the "available monitor's list" for pool but it was not available when we tried to apply it to the Node directly using "node specific" monitor setting under node configuration. Why ?
Thanks Mayank
- Ryannnnnnnnn
Altocumulus
Heya,
If you want to use a custom https monitor on a node make sure you define your https port in the "Alias Service Port" e.g. 443. After that your monitor should be available for selection when you choose node specific
