Jason_48455's avatar
Jason_48455
Jun 24, 2008
Monitor non-standard http port
I need to monitor a website running on a Flash Media server that uses port 8700.
I'm sure I'm just missing something, but how can I can I set up a monitor for this on an F5 LTM?
  • hoolio's avatar
    hoolio
    A monitor will make a request to whatever IP:port combination the pool member is defined with. Just create a new HTTP monitor and don't specify the Alias Address or Alias Service Port. For details on how to configure the send string you can search on AskF5 for 'monitor send string' or check this post (Click here).
    Aaron
  • Thanks for the help. I ended up using the information in the linked post and it worked.
