lfhx_54443's avatar
lfhx_54443
Aug 06, 2008
monitor between 2 application
Hi Guys,
I met a porblem, please give me help if you can, thanks !
we have application1 and application2
application2 is monitored by its port in a pool, if this port is down, it will be disabled
I'd like to realize that if application1 down, tell LB to disable apllication2 in its member pool
I could also monitor application1's port, and create iRules to do it
But is there any more easy way to achieve it ?
Thanks !
  • hoolio's avatar
    hoolio
    You can configure an alias address and port on a monitor to check a separate IP:port combination but mark the current pool member down if the alias IP:port doesn't respond. You can check the online help in the GUI for details on the alias IP and port options in the monitor section.
    Aaron
