errad_27550
Jul 19, 2010Monitor association that references a monitor template that does not exist.
Hello,
I'm running into an issue where an instance of a LBPoolMonitorAssociation, returned by LBPool.get_monitor_association(), has a LBMonitorRule that references a monitor template that does not exist.
Consequently, when I call Monitor.get_template_destination(template_name), to retrieve the IP : Port for the template, I get the following error message:
Exception caught in LocalLB::urn:iControl:LocalLB/Monitor::get_template_destination()
Exception: Common : : OperationFailed
primary_error_code : 16908342 (0x01020036)
secondary_error_code : 0
error_string : 01020036:3:
The requested monitor template (xxx ltm_obj) was not found.
I'm not sure what event caused the template not to exist. Under what conditions can this happen? Is it possible to remove a monitor template that is currently part of a monitor association?
Thanks,
Eric
- samstep
Cirrocumulus
Eric,
This sounds like a corrupt configuration to me - does this pool & monitor look OK using Web GUI?
" The requested monitor template (xxx ltm_obj) was not found. " basically means you asked for a non-existent monitor name.
Try doing a "b save" from the command line and look at the bigip.conf file to see if indeed somehow you have managed to have a non-existent monitor reference in the pool definition.
Sam - errad_27550
No, the monitor does not show up in Monitors but does show up as attached to pools.
Looking at the conf file was what led me to discover it was a monitor association that references a monitor template that does not exist. Over 10 pool definitions reference a monitor that does not exist.
Is a corrupt configuration the only means of causing this problem?
Is it possible to remove a monitor template that is currently referenced by pool definitions via the iControl API? - samstep
Cirrocumulus
To answer your second question:
I tried to delete a monitor template which is associated with a pool using iControl and got a SOAP exception:Exception caught in LocalLB::urn:iControl:LocalLB/Monitor::delete_template() Exception: Common::OperationFailed primary_error_code : 17236099 (0x01070083) secondary_error_code : 0 error_string : 01070083:3: Monitor test_monitor is in use
With regards to the first question - difficult to say what caused this- it iooks like that your box's config could be in a strange/unstable state, so I would not try to make sense of any iControl errors until you get the box to run in a stable configuration.
