huynh_van_dong_
Jul 06, 2009Modify of [PROFILE::http ramcache_max_age]
I want to modify [PROFILE::http ramcache_max_age] with the iRules, but i don't know how to do. Could you help me ?
Thanks,
Van Dong
- hoolio
I don't think you can use PROFILE:: to set any configuration option. You can use CACHE::expire to remove objects from the cache. Here is an example from the Codeshare (http://devcentral.f5.com/wiki/default.aspx/iRules/UsingIRulesToManipulateCache.html Click here). Or if you do want to change the actual configuration of the HTTP profile option, you could use an iControl script.
Aaron
