forsan_102218
10 years agoMirroring between two vCMP guests
I have questions regarding mirroring. Is it possible to get mirroring working between...
1) two vCMP guests running on the same blade?
2) two vCMP guests running on two different blades in one chassi?
Best Regards
Andréas
- Stephan_Mierau
Employee
what do you mean with mirroring? If you want to build a cluster between two vCMP Guest, yes this is possible, on the same blade and on different blades.
just my 2 cent,
Stephan
- amolari
vCMP guest HA (DSC clustering) is not supported in the same chassis.
"two guests must reside on separate chassis"
Alex
