Muhammad_Irfan1
Cirrus
Oct 14, 2014Memory Usage and Active connections
What does this OTHER physical memory usage means?
For now there is almost no traffic passing through F5 but still its showing 19.1% physical memory usage. In which I am using only 4.7%.
What are these open connections? Any traffic passing through F5 (non load balance) is considered as connection?
- Hannes_Rapp
1) Other is a summary of every module except TMOS/TMM. For an overview of your modules and provisions try
. Unless you have ASM/APM/AVR or other modules provisioned, "Other" is just the system management. 2) Yes, every connection routed through F5 is an active connection (until timed out or closed).tmsh show sys provision- I guess other modules are not in my control. By the way what are those other modules.
- Hannes_Rapp_162
Nacreous
