Amit_4274
May 04, 2014May 4 18:15:02 localhost emerg logger: Re-starting mcpd
I have installed F5 LTM VE (Trial) on Hypervisor. After assigning IP address to NIC interface, it is showing below error message continuously on my F5 console:
May 4 18:17:24 localhost emerg logger: Re-starting mcpd
May 4 18:17:26 localhost emerg logger: Re-starting mcpd
May 4 18:17:28 localhost emerg logger: Re-starting mcpd
May 4 18:17:30 localhost emerg logger: Re-starting mcpd
May 4 18:17:32 localhost emerg logger: Re-starting mcpd
May 4 18:17:34 localhost emerg logger: Re-starting mcpd
May 4 18:17:36 localhost emerg logger: Re-starting mcpd
May 4 18:17:38 localhost emerg logger: Re-starting mcpd
May 4 18:17:40 localhost emerg logger: Re-starting mcpd
- KG_50780
Same story on VE AMI. Happens on second boot up after initial install and config. HTTP gui is hung up also "Restarting Configuration Utility" iRule editor hangs up and crashes with a .NET error. - Hamish
Cirrocumulus
What version have you installed? The real VE with an eval license? Or the really really old v10 trial version (That you really don't want to try).
H
- Urs_Schwarz_122
Hi I have the exact same problem after changing AWS instance type from running with m3.large to c3.xlarge. Change required because hitting the sec.private IP address limit. Admin GUI also hangs as above, access via ssh is possible, but states INOPERATIVE, along with the above emerg logger message V 11.5.1 Urs
