Eric_27708's avatar
Eric_27708
Aug 04, 2011
Maximum number of allowed recursions exceeded
We recently got the F5 & the Application Security module and enabled it for a test app.
I have not enabled any learning and enabled the default out-of-the box ruleset in transparent alarm mode to understand the working of the ASM.
I am seeing a lot of false attack signature alerts with the following description "The signature is not matched. The matching process exceeded the maximum number of allowed recursions".
For SQL injection attack alerts here is what I see.
Context = Parameter
Parameter Level = Global
Wildcard Parameter Name = *
Actual Parameter Name = value
Parameter Value = "A TEXT MESSAGE GOES HERE"
Detected Keywords =
Description = The signature is not matched. The matching process exceeded the maximum number of allowed recursions
For XSS alerts here is what I see.
Context = Request
Detected Keywords =
Description = The signature is not matched. The matching process exceeded the maximum number of allowed recursions.
Am I doing something fundamentally incorrect here? Do I need to specify what rules need to apply for what parameters and pages etc.,? How do i fix this issue?
When I looked through the help pages, it mentioned that there is a default size of 5000 so that each request do not take up too much resources and increasing this number can fix this error. However, some of the requests where the alert gets triggered is a simple GET request with 5 - 10 headers and some cookies. I am not sure what the number 5000 means exactly and how such a small request can cause the maximum number of allowed recursions to exceed.
Thanks for any and all help.
  • hoolio's avatar
    hoolio
    Hi Eric,
    I'd open a case with F5 Support referencing SOL12250:
    sol12250: The BIG-IP ASM attack signature engine has a limited maximum recursion depth
    http://support.f5.com/kb/en-us/solutions/public/12000/200/sol12250.html?sr=15957522
    Aaron
  • Hi,
    It seems its still an open issue. http://support.f5.com/kb/en-us/solutions/public/12000/200/sol12250.html
    Bug ID - 293513
