Puli's avatar
Puli
Sep 11, 2012
Match and split a URI
How can i match and split a URI,
like below, eg :
http:/abc.com/about/communityprocess/maintenance/JMF2.0/$
re-direct to
abc.com/landingpage/$1
For example
http:/abc.com/about/communityprocess/maintenance/JMF2.0/hello.html re-direct to abc.com/landingpage/hello.html
it does'nt have to be just the filename, it could a url
http:/abc.com/about/communityprocess/$ re-direct to abc.com/landingpage/$1
How can match , extract the second part of incomming url and attached to the re-direct ?
thanks,
Puli.
  • hoolio's avatar
    hoolio
    You could use a switch statement for this. You can try something like this:
    log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::method] to [HTTP::host][HTTP::uri]"
    switch -glob [string tolower [HTTP::uri]] {
    "/about/communityprocess/maintenance/JMF2.0/hello.html" {
    log local0. "[IP::client_addr]:[TCP::client_port]: Redirecting to http://abc.com/landingpage/hello.html"
    HTTP::redirect "http://abc.com/landingpage/hello.html"
    "/about/communityprocess/*" {
    log local0. "[IP::client_addr]:[TCP::client_port]: Redirecting to http://abc.com/landingpage/"
    HTTP::redirect "http://abc.com/landingpage/"
    If you need to take part of the original URI and include it in the redirect, you can use getfield to split it:
    HTTP::redirect "http://abc.com/landingpage/[getfield [HTTP::uri] "/about/communityprocess/" 2]"
    Aaron
