Duncan_Proffitt's avatar
Duncan_Proffitt
Dec 22, 2017
Mass print of SSL certs and their Virtual Servers/Profiles
I have a fairly onerous task ahead of me and would like some advice please.
I have 11 BigIP to administer and all of them have a "bazillion" SSL certificates. All of those certificates will be attached to something.
Having read this post about Which Virtual Contents are associated with which SSL cert I got to thinking how would I automate this.
So, my question is; Is there a command that will give me each one of the certs with their profiles (and then their servers) that I can put into a text file and start going through each one to see if its still in use or not?
The equiring mind of a desperate F5-er would like to know, or his New Year will be locked in a darkened room running single line commands .. .
  • e.g.
    // config
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list sys file ssl-cert certone.crt
    sys file ssl-cert certone.crt {
        certificate-key-size 2048
        checksum SHA1:1021:6b81a94a572bafe3b3bc25384a4cfe747b5504c0
        create-time 2017-12-23:07:21:10
        created-by admin
        expiration-date 1545520870
        expiration-string "Dec 22 23:21:10 2018 GMT"
        issuer CN=certone.local,C=US
        key-type rsa-public
        last-update-time 2017-12-23:07:21:10
        mode 33188
        revision 1
        serial-number 251652070
        size 1021
        source-path /config/ssl/ssl.crt/certone.crt
        subject CN=certone.local,C=US
        updated-by admin
        version 3
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm profile client-ssl client-ssl-one
    ltm profile client-ssl client-ssl-one {
        app-service none
        cert certone.crt
        cert-key-chain {
            certone {
                cert certone.crt
                key certone.key
        chain none
        inherit-certkeychain false
        key certone.key
        passphrase none
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual test-one
    ltm virtual test-one {
        destination 1.2.3.4:443
        ip-protocol tcp
        mask 255.255.255.255
        profiles {
            client-ssl-one {
                context clientside
            tcp { }
        source 0.0.0.0/0
        translate-address enabled
        translate-port enabled
        vs-index 4
    // one-liner script
    [root@bip1a:Active:In Sync] config  for i in `tmsh list sys file ssl-cert one-line |awk '{print $4}'`; do echo "===== cert: $i ===="; for j in `tmsh list ltm profile client-ssl one-line |grep $i |awk '{print $4}'`; do echo "----- profile: $j -----"; for k in `tmsh list ltm virtual one-line |grep $j |awk '{print $3}'`; do echo "virtual: $k"; done; done; echo ""; done
    ===== cert: ca-bundle.crt ====
    ===== cert: certone.crt ====
    ----- profile: client-ssl-one -----
    virtual: test-one
    ===== cert: default.crt ====
    ----- profile: clientssl -----
    ----- profile: clientssl-insecure-compatible -----
    ----- profile: clientssl-secure -----
    ----- profile: crypto-server-default-clientssl -----
    ----- profile: wom-default-clientssl -----
    ===== cert: f5-irule.crt ====
    • Duncan_Proffitt's avatar
      Duncan_Proffitt
      You amazing human being!! I want your babies!!
      In other words;
      Thank you very much, the one liner is perfect!!
      D.
  • e.g.
    // config
        created-by admin
        key-type rsa-public
        mode 33188
        revision 1
        size 1021
        updated-by admin
        version 3
        app-service none
        cert certone.crt
        cert-key-chain {
            certone {
                cert certone.crt
                key certone.key
        chain none
        key certone.key
        passphrase none
        ip-protocol tcp
        profiles {
            client-ssl-one {
                context clientside
            tcp { }
        source 0.0.0.0/0
        vs-index 4
    // one-liner script
    virtual: test-one
      Duncan_Proffitt
      In other words;
      D.
  • how would I get the details off a non-common partition?
    do you happen to have virtual server which uses clientssl profile from another partition or clientssl profile that uses certificate from another partition? if yes, it will not be recognized by the one-liner script (below). it is because how the script is built (we are filtering virtual server based on clientssl profile based on certificate in specific partition).
    there are 4 folders including root.
    root@(bip1a)(cfg-sync In Sync)(Active)(/)(tmos) list sys folder |grep sys
    sys folder / {
    sys folder Common {
    sys folder asgard {
    sys folder jotunheim {
    each folder except root has its own certificate, clientssl profile and virtual server.
    // common
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list sys file ssl-cert cert-one.crt
    sys file ssl-cert cert-one.crt {
        checksum SHA1:1013:76f6b8023a53f91defdb335f1df514337070c631
        create-time 2017-12-28:21:18:37
        created-by admin
        expiration-date 1546003117
        expiration-string "Dec 28 13:18:37 2018 GMT"
        issuer CN=one.local,C=US
        key-type rsa-public
        last-update-time 2017-12-28:21:18:37
        mode 33188
        revision 1
        serial-number 252134317
        size 1013
        source-path /config/ssl/ssl.crt/cert-one.crt
        subject CN=one.local,C=US
        updated-by admin
        version 3
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm profile client-ssl clientssl-one cert key
    ltm profile client-ssl clientssl-one {
        cert cert-one.crt
        key cert-one.key
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual vs-one profiles
    ltm virtual vs-one {
        profiles {
            clientssl-one {
                context clientside
            tcp {
                context all
    // asgard
    root@(bip1a)(cfg-sync In Sync)(Active)(/asgard)(tmos) list sys file ssl-cert cert-heimdall.crt
    sys file ssl-cert cert-heimdall.crt {
        checksum SHA1:1025:e787e6f665058d1d43d4d7d780ec69014bbfbcc5
        create-time 2017-12-28:21:15:19
        created-by admin
        expiration-date 1546002919
        expiration-string "Dec 28 13:15:19 2018 GMT"
        issuer CN=heimdall.local,C=US
        key-type rsa-public
        last-update-time 2017-12-28:21:15:19
        mode 33188
        partition asgard
        revision 1
        serial-number 252134119
        size 1025
        source-path /config/ssl/ssl.crt/cert-heimdall.crt
        subject CN=heimdall.local,C=US
        updated-by admin
        version 3
    root@(bip1a)(cfg-sync In Sync)(Active)(/asgard)(tmos) list ltm profile client-ssl clientssl-heimdall cert key
    ltm profile client-ssl clientssl-heimdall {
        key cert-heimdall.key
    root@(bip1a)(cfg-sync In Sync)(Active)(/asgard)(tmos) list ltm virtual vs-heimdall profiles
    ltm virtual vs-heimdall {
        profiles {
            /Common/tcp {
                context all
                context clientside
    // jotunheim
    root@(bip1a)(cfg-sync In Sync)(Active)(/jotunheim)(tmos) list sys file ssl-cert loki-cert.crt
    sys file ssl-cert loki-cert.crt {
        checksum SHA1:1013:bbf5b8a4020b415690e6f87a1c6d8222d6aa4a7d
        create-time 2017-12-28:21:16:09
        created-by admin
        expiration-date 1546002969
        expiration-string "Dec 28 13:16:09 2018 GMT"
        issuer CN=loki.local,C=US
        key-type rsa-public
        last-update-time 2017-12-28:21:16:09
        mode 33188
        partition jotunheim
        revision 1
        serial-number 252134169
        size 1013
        source-path /config/ssl/ssl.crt/loki-cert.crt
        subject CN=loki.local,C=US
        updated-by admin
        version 3
    root@(bip1a)(cfg-sync In Sync)(Active)(/jotunheim)(tmos) list ltm profile client-ssl clientssl-loki cert key
    ltm profile client-ssl clientssl-loki {
        cert loki-cert.crt
        key loki-cert.key
    root@(bip1a)(cfg-sync In Sync)(Active)(/jotunheim)(tmos) list ltm virtual vs-loki profiles
    ltm virtual vs-loki {
        profiles {
            /Common/tcp {
                context all
            clientssl-loki {
                context clientside
    but this jotunheim folder has special virtual server/clientssl profile which refers to certificate in common folder. this virtual server/clientssl profile will not be flagged by the one-liner script below.
    root@(bip1a)(cfg-sync In Sync)(Active)(/jotunheim)(tmos) list ltm virtual vs-special profiles
    ltm virtual vs-special {
        profiles {
            /Common/tcp {
                context all
            clientssl-special {
                context clientside
    root@(bip1a)(cfg-sync In Sync)(Active)(/jotunheim)(tmos) list ltm profile client-ssl clientssl-special cert key
    ltm profile client-ssl clientssl-special {
        cert /Common/cert-one.crt
        key /Common/cert-one.key
    [root@bip1a:Active:In Sync] config  for p in `tmsh -c "cd /; list sys folder one-line" |awk '{if($3~/^\//) {print $3; next} {print "/" $3}}'`; do echo "===== partition: $p ====="; for i in `tmsh -c "cd $p; list sys file ssl-cert one-line" |awk '{print $4}'`; do echo "----- cert: $i -----"; for j in `tmsh -c "cd $p; list ltm profile client-ssl one-line" |grep $i\ |awk '{print $4}'`; do echo "***** profile: $j *****"; for k in `tmsh -c "cd $p; list ltm virtual one-line" |grep $j\ |awk '{print $3}'`; do echo "..... virtual: $k ....."; echo ""; done; done; done; echo ""; done
    ===== partition: / =====
    ===== partition: /Common =====
    ----- cert: ca-bundle.crt -----
    ----- cert: cert-one.crt -----
    ***** profile: clientssl-one *****
    ..... virtual: vs-one .....
    ----- cert: default.crt -----
    ***** profile: clientssl *****
    ***** profile: clientssl-insecure-compatible *****
    ***** profile: clientssl-secure *****
    ***** profile: crypto-server-default-clientssl *****
    ***** profile: wom-default-clientssl *****
    ----- cert: f5-irule.crt -----
    ===== partition: /asgard =====
    ----- cert: cert-heimdall.crt -----
    ***** profile: clientssl-heimdall *****
    ..... virtual: vs-heimdall .....
    ===== partition: /jotunheim =====
    ----- cert: loki-cert.crt -----
    ***** profile: clientssl-loki *****
    ..... virtual: vs-loki .....
    i have another idea which uses icontrol rest and jq. since icontrol rest is not limited to single partition. all virtual servers and clientssl profiles should be recognized even it uses configuration object from another partition.
    [root@bip1a:Active:In Sync] config  for i in `curl -sk -u admin:admin https://localhost/mgmt/tm/sys/file/ssl-cert |jq '.items[]|{fullPath}' |awk '/fullPath/ {print $2}'`; do echo "===== cert: $i ====="; for j in `curl -sk -u admin:admin https://localhost/mgmt/tm/ltm/profile/client-ssl |jq ".items[]|select(.cert==$i)|{fullPath}" |awk '/fullPath/ {print $2}'`; do echo "----- profile: $j -----"; for k in `curl -sk -u admin:admin https://localhost/mgmt/tm/ltm/virtual?expandSubcollections=true |jq ".items[]|select(.profilesReference.items[].fullPath==$j)|{fullPath}" |awk '/fullPath/ {print $2}'`; do echo "virtual: $k"; echo ""; done; done; echo ""; done
    ===== cert: "/Common/ca-bundle.crt" =====
    ===== cert: "/Common/cert-one.crt" =====
    ----- profile: "/Common/clientssl-one" -----
    virtual: "/Common/vs-one"
    ----- profile: "/jotunheim/clientssl-special" -----
    virtual: "/jotunheim/vs-special"
    ===== cert: "/Common/default.crt" =====
    ----- profile: "/Common/clientssl" -----
    ----- profile: "/Common/clientssl-insecure-compatible" -----
    ----- profile: "/Common/clientssl-secure" -----
    ----- profile: "/Common/crypto-server-default-clientssl" -----
    ----- profile: "/Common/wom-default-clientssl" -----
    ===== cert: "/Common/f5-irule.crt" =====
    ===== cert: "/asgard/cert-heimdall.crt" =====
    ----- profile: "/asgard/clientssl-heimdall" -----
    virtual: "/asgard/vs-heimdall"
    ===== cert: "/jotunheim/loki-cert.crt" =====
    ----- profile: "/jotunheim/clientssl-loki" -----
    virtual: "/jotunheim/vs-loki"
      Duncan_Proffitt
      Thank you for all of that. So, on the GUI, I navigate to SSL Cert List There I drop down the partition drop-down and not only do I have Common, but I have two other partitions.
      Lets call them red and green
      Both Red and Green use Common partition/path certs as well as certs individual to their own partition.
      You have very kindly helped me previously with the Common certs, and once again, you have scored another goal with this one liner!!
      Thank you so much again!
    • nitass_89166's avatar
      nitass_89166
      Icon for Noctilucent rankNoctilucent
      very welcome. what you are asking makes sense. i was enjoying playing around with it and hope i can use it too!
      Duncan_Proffitt
    • nitass's avatar
      nitass
