Manual Failover with tmm restart
Hi!
I just would like to ask if there is a way to perform a manual failover with tmm restart simultaneously? Similar to what is in the failsafe option?
Thank you.
- nitass
Employee
doesn't it failover automatically when restarting tmm (e.g. bigstart restart)?
- Ephraine_Tabila
Hey Nitass! How are you? Its been awhile huh?
Yes it does! Thanks! But if this is done, the failover will still be seamless, right?
- nitass
Employee
i am doing good. how have you been? i do not think it is seamless. i mean service (user) will be interrupted.
- Ephraine_Tabila
im good, still handling LTM :)
but the service interruption is similar to the instance where we will just click "Force to Standby" button on the active unit?
- nitass
Employee
i am not sure whether it is the same indeed. anyway, i would prefer failover manually (force standby) and then restart tmm on new standby unit.
- Ephraine_Tabila
Hi Nitass, just retested the tmm restart command. It seems the failover will just be temporary. After the tmm restart process has finished, the box will retain its position as active.
- StephanManthey
Nacreous
Hi Ephraine, what software version are you on? Are there any configurations regarding unit preference in HA settings? Is there anything with the second unit preventing it from going active? Btw, in case of both units in standby the one with the higher management IP will win. Thanks, Stephan
