kevin_50596
Aug 19, 2008Maintenance Window with Security
Regarding the irule discussed here:
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=70
Is there any way to build some kind of client IP based security into the rule? All of our admin traffic comes from 192.168.1.99 as far as the bigIPs know, so I would want to restrict the /enable, /disable etc. pages referenced in the irule to be accessible from that address only.
Thanks!
Kevin
- Nicolas_Menant
Employee
you can do it by controlling IP addresses that are authorized to connect.
You can have a look here: Click here - kevin_50596
Thanks for the reply, I've got it restricted to traffic generated from a specific IP, is there any way to use the BigIP to password protect the /enable, /disable, /check, and /usage pages with username and password? I don't think LDAP authentication will be possible but was hoping for some other method?
