fubarSUSHI's avatar
fubarSUSHI
Mar 12, 2014
Maintenance page per status code received
Im trying to find an iRule that can do a maintenance page depending on what status code is given... for example:
status code 3xx - go to maintenance page 1 - "Your request has been redirected"
status code 4xx - go to maintenance page 2 - "Your request has received a client error"
status code 5xx - go to maintenance page 3 - "Your request has received a server error"
Im using a basic/simple maintenance page:
 Check and verify that there are Pool Members Available to server the request
if { [active_members [LB::server pool]] < 1 } {
     If there are no members available, generate HTML Maintenance Page
    HTTP::respond 200 content "Site unavailable
    System Maintenance
    NOTICE: This site is under maintenance.
Im hoping to find a simple solution to use the response code results and give them a html response with simple text that is hosted by the F5. The fallback host setup will not work for this request.
  • So your irule will work as-is for when there are no servers available. Now you need to look at the responses when there ARE servers and intercept/replace that response. So just add this to the bottom of your iRule.
    when HTTP_RESPONSE {
      switch [HTTP::status] {
        "3*" {
          HTTP::respond 200 content "Your 3xx content here"
        "4*" {
          HTTP::respond 200 content "Your 4xx content here"
        "5*" {
          HTTP::respond 200 contetn "Your 5xx content here"
    This is very basic and there could certainly be some further error checking, logging, and handling done if needed. This will give you a start though.
    Joe
    • fubarSUSHI's avatar
      fubarSUSHI
      Wow... thanks. Ill have to check this out and see if it works!
