hung_105573's avatar
hung_105573
Oct 10, 2012
Mail Zimbar behind F5 have problem port 995
Hi all
I'm facing problem port 995 mail server Zimbra , I had config virtual access mail via port 995 on MS Outlook from internet to mail server inside network , sometime receive error information ssl
you would like to see file attached
pls help me
thank all
  • Hi
    my config virtual as:
    ltm virtual Mail_POP3SSL_FPT1 {
    destination 118.69.x.x:pop3s
    ip-protocol tcp
    mask 255.255.255.255
    persist {
    source_addr {
    default yes
    pool Server_10.0.25.91_995
    profiles {
    tcp { }
    snat automap
    vlans {
    FPT_LL1
    vlans-enabled
    pls help me
    thanks
  • A few Google's suggest this is either an Outlook or AV software issue;
    http://www.zimbra.com/forums/users/43094-solved-outlook-2007-account-setup.html
    http://answers.microsoft.com/en-us/office/forum/office_2010-outlook/in-outlook-2010-i-receive-error-report-0x800ccc1a/74f2a191-69db-4ad2-8a48-a73fd2250d85
    As the first article suggests, switching to IMAP (whether it solves this issue or not, although I think it will) is probably your best course of action for many reasons.
  • Hi all
    I had check , the users from internet access mail via outlook with port 995 work fine , Only Users inside access mail port 995 then some time get this errors .
    My config virtual for traffic outbound :
    ltm virtual Mail_Server_Port995 {
    destination 0.0.0.0:pop3s
    ip-protocol tcp
    mask any
    persist {
    dest_addr {
    default yes
    pool Default_Gateway_Mail_Server
    profiles {
    tcp { }
    rules {
    Source_MailServer
    translate-address disabled
    vlans {
    Internal
    vlans-enabled
    the Defaul_Gateway_Mail_Server have 2 member ip public internet
    the rules Source_MailServer :
    when CLIENT_ACCEPTED {
    if { [IP::addr [IP::client_addr] equals 10.0.25.91] } {
    snatpool Mail_Server
    else
    snatpool Nat_Internet_live
    the Ip 10.0.25.91 ip address of mail server
    the snatpool Mail_Server have 2 ip mx record
    snatpool Nat_Internet_live have 2 ip public internet
    pls help me
    thanks all
  • are you able to capture packet while getting an error?
    tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x
    x.x.x.x is mail server ip which user inside connects to
    please also note client ip and source port number. it might be useful when checking the capture file.
    hope this helps.
  • hi all
    when i change type vs from standard to performance then work fine
    thanks
  • Hi Hung,
    May be you were using the AVR in the Standard VS???? if yes try it after removing the AVR and see if it works.
    Regards,
