mabdrasol's avatar
mabdrasol
May 26, 2019
LTM+GTM at same box
we have two LTM nodes at HA setup and we need to migrate External DNS to F5 GTM
LTM and GTM license at same node
but I cant find a clear steps to do that or the best practices.
  • Hello Oscar,
    thanks for great tips.
    now I have added
    -F5 node with two self ips
    -create listener ip
    -create pool with existing LTM VS.
    -create wideip with a record for this pool.
    -use dig tool to test dns resolving using listening ip from internal lan and resolving worked fine.
    now I need to use this test from WAN side but I have a confusion here
    here is my design
    remote user >>WAN>>NET Router>>FW>>F5 DNS>>F5 LTM>>server
    how to map VIP private IP to Real IP?
    listener IP is a private IP do I need to NAT it in internet firewall to real IP?
  • if the devices are in HA, add both non-floating self-ips one for each device. But still add only once, so lets say the HA pair has these two devices:
    -ltm01
    -ltm02
    then add the HA pair with a name like this: ltm01-02 and use the non-floating self ip for each device. Important point is that even you have two devices, because they are in HA, you just add once.
    • AshrafKassem's avatar
      AshrafKassem
      can you please, explain to me what you mean? I have same setup HA LTM working as Active/Standby and i will add GTM License to the box.
      should I login to the active F5 and add Two servers with Self-IP (one for active and for standby)?
      should I do this step on active and standby F5?
      should i use the Synck group in GTM?
  • Hi, The selfip belongs to the device itself, it doesn't matter if you are using LTM or GTM, so, just add the device once, with the non-floating selfip and that's it. If you have LTM provisioned and you want to discover the Virtual Servers, then enable Virtual Server Discovery
  • Hi Oscar,
    thanks for your replay
    I'm confused here in this implementations as my f5 has below interfaces
    -self IP (for LTM)
    -floating IP (for LTM)
    -HA IP
    when I try to add GTM and LTM as a servers do I need to add more self IPs for GTM as I cant use same self IP for GTM and LTM.
  • Hi mabdrasol,
    it can be done, no problem on using LTM and GTM on the same box. In regards to best practices, I would suggest you create the DNS configuration on your GTM devices, create listener with an IP address different to the current one serving the DNS request. Test extensively via dig/lookups and only when you are sure all is good, you perform the cutover re-pointing the NS records to the GTM's listeners.
    Best Regards,
    Oscar Pucheta
    https://www.australtech.net
    https://www.linkedin.com/in/npucheta/
