PeteW's avatar
PeteW
Dec 12, 2012
LTM6800 to Viprion chassis
Chaps,
It looks like I'll be tasked with migrating a pair of active/passive 6800 LTM BigIP's to a new pair of Viprion 2400 chassis.
The current kit is running v9.4.5 with around 160VIPS and about 20 iRules that call various DGL's etc.
As I need to keep the current kit in place and build the Viprion's alongside is there a preferred way to migrate the current configuration running on v9.4.5 over to the Viprion which I assume will be running v11 by default?
I had the sneaking suspicion that I would need to upgrade to a version 10 config before I could import into Viprion.
Any pointers/suggestions/migration gotchas greatly received as I anticipate a certain amount of carnage.
P.S. is it also correct that the bigpipe command has been deprecated after 10.2?
Pete
  • hoolio's avatar
    hoolio
    Hi Pete,
    This will be a bit complicated to do and I suggest you work with your F5 or partner SE to come up with a plan. As a high level overview, I'd consider:
    do the port in advance if it’s a version and platform move
    implement a change freeze on the original units
    export the config to SCF plus certs
    upgrade on the same platform or a VE to the target LTM version
    load the SCF config on the new Viprions
    adjust the interfaces in the bigip_base.conf
    If you have iRules take a look at the CMP compatibility wiki page for steps to ensure your iRules will not cause the virtual servers to run on only the first TMM instance:
    https://devcentral.f5.com/wiki/iRules.CMPCompatibility.ashx
    If you want to run both platforms simultaneously, you'd want to assign new self IPs to the Viprions before connecting any of the switch ports to the network. You could then migrate a virtual server one at a time. If you want to revert an individual service back to the original 6800 pair, you can disable ARP for the virtual address on the Viprions, enable ARP on the 6800s and clear the upstream device(s)'s ARP cache.
    Aaron
  • PeteW's avatar
    PeteW
    Thanks Aaron that really is excellent advice, much appreciated.
    Pete
  • hoolio's avatar
    hoolio
    I left out a good step:
    Before putting the new platform into production, run qkview and upload it to iHealth.f5.com to check for any known issues with your config now that you're on a version that iHealth supports.
    Aaron
  • PeteW's avatar
    PeteW
    Aaron that's great many thanks chap :)
    Pete
