Torti's avatar
Torti
Icon for Cirrus rankCirrus
Feb 18, 2014
LTM v11.5.0 - IP::addr mask not allowed anymore
I test a little bit with 11.5.0. If I try:
    when CLIENT_ACCEPTED {
        if { [IP::addr [IP::remote_addr] equals 10.10.10.0 mask 255.255.255.0] } {
             allowed
            discard
            log local0. "connection discarded from [IP::client_addr]"
I get the following tcl error:
error: /Common/iRuler_Parse_Test_Rule:2: error: [wrong args][IP::addr [IP::remote_addr] equals 10.10.10.0 mask 255.255.255.0]
With [IP::addr [IP::remote_addr] equals 10.10.10.0/24] everthing is working fine.
Is the mask parameter not allowed anymore?
  • I had a quick read through https://devcentral.f5.com/wiki/irules.ip__addr.ashx and I can't see an example that is just like yours. The closest one looks like this, with the right side of the equals wrapped in quotes.
    [IP::addr 10.42.2.2 equals "10.42.2.0 mask 255.255.255.0"]: 1
    Try it that way and see if there is any difference... Unless the old examples have been deleted, your way may never have been officially supported.
